I do have a question if someone out here has an answer. Is the north trail head being re-routed? I have marked on the attached map, the path flagged is now taking. Even though I did not follow to the end, I did get up to the point where it came up to the old firing range.
So I marked the new section in green on the map. If it is being re-routed, where will the new trail head be??
Thanks. Eric
I'm sure the trail is being re-routed. Mark with Wild South told me they were going to move it so there wouldn't be a Borden Creek crossing. There's no real good place to cross Borden and at any creek / stream crossing the impact on the creek / stream bank is always destructive. So they are routing it across the feeder stream up behind the old firing range.
I'm not sure if there will be a "new" trail head or just where it may be for now but eventually trail 203 is supposed to go the central tower on Highway 33. As you said, it's good now thanks to the work of Wild South. It will be a great trail when it is completed.
