GPS Coordinates and Google Earth
Topic: GPS Coordinates and Google Earth (Read 450 times)
Haveuseen1
Trail friend
December 11, 2009, 03:52:13 PM »
I was trying to figure out where the pointer should be to get the coordinates from Google Earth.
SmokeDiver
Toughest teddy bear around.
Trail Enthusiast
Re: GPS Coordinates and Google Earth
December 11, 2009, 04:22:24 PM »
Right click on the spot you want the coordinates for then select What's Here? and it will put a green arrow there. Mouse over that arrow or look in the search field and your numbers will be there!
He who is not everyday conquering some fear has not learned the secret of life. -Emerson
December 11, 2009, 04:24:23 PM »
Note that, in Google Maps, the procedure is the same. However, Google Maps occasionally gets confused when you do this, and while the coordinates often end up what you indended, the indication on the screen does not.
http://waterfalls.szulecki.com
http://photo.net/photos/jo7hs2
http://waterfallchasing.blogspot.com/
Haveuseen1
Trail friend
December 12, 2009, 06:44:31 PM »
Hmmmm, when I right click in google earth there is no "whats here" available.
SmokeDiver
Trail Enthusiast
December 12, 2009, 08:31:22 PM »
Whoops, I thought you asked about Google Maps, in Google Earth, click on the yellow push pin button on that tool bar above the map. It will give you coords for where ever you put a pin in.
