Pages: [1] 2 3 Next  All   Go Down
Author Topic: DIY Alcohol Stove  (Read 5323 times)
JC785
Favorite Trail: Quillian Creek
« on: August 24, 2010, 03:43:59 PM »
I have been experimenting with some alcohol stoves, but I have one problem, I am having a hard time  attaching the the two bottoms together since they are the same diameter. What have yall done to ease this process?
squidbilly
Favorite Trail: off trail
« Reply #1 on: August 24, 2010, 07:31:23 PM »
 You will have to expand either the top or bottom slightly.  Use another can to slowly work the edge outward. Don't get in a hurry, it doesn't take much....just enough to allow the other half to slip inside.You can also use a wooden dowell or a scrap of pvc pipe to slightly bend the edge out.
 Another method uses a pair of needle nose pliers to shrink the edge of one half  to allow clearance. Grab the edge and give it a slight twist-- repeat  all the way around the edge until you're back to where you started.
 Don't forget the J B weld or red rtv silicone sealant.
I love experimenting with my alky stoves.  Theres nothing like that pretty blue flame.
Dale
squidbilly
« Reply #2 on: August 24, 2010, 09:07:15 PM »
 :)Here is a short video of one of my stoves.
  <a href="http://www.youtube.com/v/NJw2qcEwjwg&rel=0" target="_blank">http://www.youtube.com/v/NJw2qcEwjwg&rel=0</a>
Dale
JC785
« Reply #3 on: August 26, 2010, 11:03:32 AM »
I have been experimenting wait a monster energy drink can the stove I just made burned for 28 min on 1.5 oz but it took 14 min to boil around 16 oz of water. I need to figure out how to make the fire a little hotter in order to get the boil time down. I will post pics when I get a chance.
wirerat123
River Rat/Trail Junkie
Favorite Trail: Hiker/Paddler : Pinhoti/Locust Fork
Referrals: 2
Avid Hiker/Paddler
« Reply #4 on: August 26, 2010, 11:23:06 AM »
I use the pliers method to crimp the top can so that it slides down into the bottom can, and seal with JB weld.
I've experimented with various size hole, various amounts of holes, and such.  18 holes around the perimeter with a thumb tack seems to produce the most consistent burn and heat.  The drilled holes work just fine, but I typically only use 8 holes when I use a tiny drill bit as the holes to often end up larger than I wanted.  More than 8 holes with the drill bit and the pressure on the inside is lowered enough that it just doesn't burn as hot.
http://www.zenstoves.net
the best info on the net when it comes to stoves and design.  Below is one of my favorite designs, but I just make simple penny stoves for the most part now.  My next project is the cat stove.
http://zenstoves.net/BasicTopBurner.htm
For a good 2oz system check this out.
http://zenstoves.net/2ozSystem.htm
« Last Edit: August 26, 2010, 11:31:01 AM by wirerat123 » Logged
Go outside!  It's beautiful out there!
squidbilly
« Reply #5 on: August 26, 2010, 12:06:07 PM »
Wirerat123, I agree with you about zenstoves. All the info and templates you could ask for-in one place.
You're gonna like the performance of the cat stove or top burner. The stove in the vid I posted is this type. Did you notice the Snow Peak mug and the windscreen/ mug holder behind the stove? I made this stove and holder just for this mug. It will boil 600ml in 5mins.
My stove is a little heavier(0.9oz) but perhaps more durable. It all nests together.
Dale
wirerat123
Referrals: 2
Avid Hiker/Paddler
« Reply #6 on: August 26, 2010, 12:56:23 PM »
That's a great setup, and kind of what I am going for.
squidbilly
« Reply #7 on: August 26, 2010, 01:32:05 PM »
JC785 /  wirerat123  check your PMs
Dale
JC785
« Reply #8 on: August 26, 2010, 01:55:04 PM »
I like the 2 oz set up, Do any of yall have any of those 24oz Heineken Cans? They don't sell them in Alabama.
JC785
« Reply #9 on: August 26, 2010, 07:29:09 PM »
That is the Monster can stove and also a coke can stove I threw together tonight. By looking at the picture would you be able to tell me how to make the monster can stove hotter.
http://www.alatrails.com/photos/albums/userpics/10249/P8261191.JPG
DIY Alcohol Stove
http://www.alatrails.com/photos/albums/userpics/10249/P8261192.JPG
DIY Alcohol Stove
http://www.alatrails.com/photos/albums/userpics/10249/P8261193.JPG
DIY Alcohol Stove
http://www.alatrails.com/photos/albums/userpics/10249/P8261194.JPG
DIY Alcohol Stove
http://www.alatrails.com/photos/albums/userpics/10249/P8261195.JPG
DIY Alcohol Stove
http://www.alatrails.com/photos/albums/userpics/10249/P8261196.JPG
DIY Alcohol Stove
squidbilly
« Reply #10 on: August 26, 2010, 10:45:58 PM »
Nice job on the stoves JC785!    I'm not sure how to make the monster burn hotter. The only thing I see that could affect performance is the jets look a little large.
 Does it work like a White Box stove?--You pour alcohol in,light it, and when the jets "blossom" you set the pot directly on the stove. The advantage to this design is you don't need a separate pot stand. One disadvantage is the slightest breeze blows heat away from your pot.
The best designs use the stand as an integral part of stove system.  The stand is a windscreen, it controls the burn(fuel/air) mixture,concentrates the heat where you need it and allows you to simmer. A system that does this is going to perform better for you in a wide range of conditions
Heres a good stove :http://www.thermojetstove.com  Read the section on combustion basics.
Dale
wirerat123
Referrals: 2
Avid Hiker/Paddler
« Reply #11 on: August 27, 2010, 06:30:54 AM »
I agree, the jets look much to large to me.  Use a #74 Drill bit if you can find one, or a simple thumb tack.  It'll increase the pressure in the system and the stove will burn hotter for longer.
The larger the hole the more dependable the flame will be, but it will not burn nearly as efficient.  Large holes can also throw off the air/fuel ration and cause the stove to not burn as hot as it could.  That is most likely the issue with your stove.
The smaller the holes the hotter and more efficient your flame will be, but the easier it will be for the flame to be disrupted by a breeze, or a pressure fluctuation within the stove itself.
If I am using a #74 bit I would put around 14 to 16 evenly spaced holes around the can.  If I had a #80 I would use upwards of 20+.  With a thumb tack I will put around 14 in it.
With a thumb tack I tend to try get the tack pushed only partially in as to not get the holes the full diameter of the push pin shaft.  Just get the holes started and all fairly evenly sized and test the stove, if it doesn't seem to be performing right, I'll push it farther into the offending jets increasing the opening until they all perform evenly.
The stove looks great except for the size of the jets.  The inner jetted penny stove looks like it should work fine.
Yesterday I found 2 8oz Coors cans I plan to make a stove out of.  Smaller and lighter than standard cans, but should get the same burn results as the larger cans.  Only smaller fuel capacity.
« Last Edit: August 27, 2010, 07:31:40 AM by wirerat123 » Logged
JC785
« Reply #12 on: August 27, 2010, 07:30:07 AM »
Thanks for the advice, I went by 2 gas stations on the way to work to try and find another monster can like the one I used but I had no luck. I got the one I had at Wal-Mart so hopefully they still have some.
squidbilly
« Reply #13 on: August 27, 2010, 07:58:36 AM »
JC785, check this stove out.  Easy to make. Durable-thicker aluminum. I have several empties.
<a href="http://www.youtube.com/v/tjHpihZ9ubc&rel=0" target="_blank">http://www.youtube.com/v/tjHpihZ9ubc&rel=0</a>
« Last Edit: August 27, 2010, 08:15:07 AM by squidbilly, Reason: try to fix link » Logged
Dale
JC785
« Reply #14 on: August 27, 2010, 08:00:51 AM »
  http://http://www.youtube.com/watch?v=tjHpihZ9ubc
The link is not working for some reason. How many holes should I have in the center of the can down at the bottom, I have 2 on the one in the picture.
« Last Edit: August 27, 2010, 08:04:54 AM by JC785 » Logged
squidbilly
« Reply #15 on: August 27, 2010, 08:11:10 AM »
The two holes in your stove should work fine.  I have not built this type of stove though--so I can't say for sure.
Dale
squidbilly
« Reply #16 on: August 27, 2010, 08:17:39 AM »
Check it now.
Dale
JC785
« Reply #17 on: August 27, 2010, 08:24:31 AM »
I made one of those as well I think I made the holes to big in it because the flames were huge.
squidbilly
« Reply #18 on: August 27, 2010, 09:07:17 AM »
I guess smaller is better in this case.  Like wirerat123 said, you can use a tack on the thin cans. On the thicker ones you need a small drill bit.
Hobby Lobby sells a pin vise that comes with several very small bits for about 18$.    Dremel makes a set of seven bits from 1/32"-1/8".  I used the 1/32" bit for my burners. (24 holes)
Dale
Firedog
Paddler, Hiker, EMT, Diver
Favorite Trail: Odum Scout Trail
Referrals: 3
« Reply #19 on: August 27, 2010, 11:39:38 PM »
24-1/32" holes 1/2 " from the top is perfect. Your holes in the center are just to let the fuel drain into the bottom so 2 are fine. If you use the Aluminum bottle design, epoxying the two parts together is not necessary, If you drive the inside part in, it will seal good enough. Make sure you smooth the top edge on a belt sander so the pot seals aginst the top of the can, This will help make the pressure to give you a more efficient burn.
I really like the Aluminum bottle stove. It is similar to the Whitebox stove in that with the well in the center it preheats faster.
Carl Wilson
Pages: [1] 2 3 Next  All   Go Up
