Hi flemdawg1,
I can't speak to the one you referenced, but I did purchase the Stratus woodburning camp stove
http://www.trailstove.com/We used it on an overnight backcountry hike to Providence Canyon Georgia in March. The stove weighs less than 2 pounds (though I have not actually weighed it) and includes the stove (a modified cylinder with a removable grate), short tubing (for blowing extra air if needed), and it's nylon carrying sack.
I was impressed with the stove's ability to get hot quickly and boil all the water needed to feed a group of about 10! I did not have to pack a pocket rocket or other stove nor worry about packing fuel in and out. There was plenty of dry (or almost dry) sticks all around!
It passed my tests and has a permanent place in my gear selection. Having said that, there are a couple of things to keep in mind:
-- The stove can get sooty (depends on what type of sticks you're burning) - requires a clean up after getting home.
-- Gets hot quickly, but it IS NOT as quick as a Pocket Rocket or similar. I was able to boil a liter of water in just a couple of minutes (after letting the fuel catch well)
-- Requires lots of small sticks, etc. to be fed often IF you're cooking for a large group or for a long period of time.
-- If you don't like the smell of wood burning, then you will not like this cooker.
-- Naturally, would only work in areas where natural fuels are available (which is usually the case).
Just my thoughts... hope they help.
